ESP32-C3-WROOM-02 AT FIRMWARE +IPD WRONG DATA
vinodstanur
Postby vinodstanur » Wed Mar 20, 2024 1:07 pm
<r>Hello,<br/>
<br/>
I am using esp32c3-wroom-02 module.<br/>
I flashed it with appropriate AT firmware.<br/>
I am runing <br/>
<br/>
AT+CIPMUX=1<br/>
AT+CIPMUX=1<br/>
<br/>
OK<br/>
AT+CIPSERVER=1<br/>
AT+CIPSERVER=1<br/>
<br/>
OK<br/>
<br/>
<br/>
Then I am connecting from socket client software from PC, sending different data sizes like 100, 502, 1000 etc but mostly if packet size is around 500 or above, the response data is most of the time corrupted for +IPD format. Even many times +IPD is not coming but some part of the tcp data is showingup, this is completely buggy and cannot be used at all.<br/>
<br/>
After that I did custom build the AT firmware for stm32c3 and tried many modifications but everytime this weird behaviour is consistent, I tried to increase queue size for tx but nothing helps.<br/>
<br/>
Can someone try it and replicate it quickly and see why this is happening ? I tried of 3 different modules and same beahaviour, so it is definitely something wrong with the AT firmware.<br/>
<CODE><s>
</s>no external 32k oscillator, disable it now.
at param mode: 1
ready
+STA_CONNECTED:"00:13:25:ab:d2:37"
+DIST_STA_IP:"00:13:25:ab:d2:37","192.168.4.2"
AT+CIPMUX=1
AT+CIPMUX=1
OK
AT+CIPSERVER=1
AT+CIPSERVER=1
OK
0,CONNECT
+IPD,0,12:1111111111
+IPD,0,102:1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
+IPD,0,502:11111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
1
1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
11111111111
111111111111
11111111
11
111
1
111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111ËÐGn[18]ÿF[00]ÐþF[00] rJnIŠLnR£¬W[18]/G[00] ”Ln[18]/G[00]tõ
[00]tõ
[00]‘ŽOnÿÿÿÿIŠLn+”Ln€õ
[00]Ç®GnÈ[1D]G[00][00]5Hnà.G[00][00]5Hn>¢Gn꣬W[00][00][00][00]ÿF[00][00][00]G[00][00][00]b[02][00][00][00][00]pàb[02]«”On[01][00][00][00]Àö
[00][03][07]æwX[02]b[02]ö[05]æw‡DÂXXáb[02][00][00]b[02][00][00][00][00]
111111111111111
[00]tõ
+IPD,0,1002:1111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111111
<e>
</e></CODE>
Screenshot 2024-03-20 170445.png (31.4 KiB) Viewed 6471 times
--------update--
Again I made the server on 80 port and tried to hit url (3 times after closing connection)
http://192.168.4.1/AAAAAAAAAAAAAAAAAAAA ... AAAAAAAAAA
And I am getting sometimes wrong data in esp32 TX as below
1,CLOSED
1,CONNECT
+IPD,1,707:GET /AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADDAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA HTTP/1.1
Host: 192.168.4.1
Connection: keep-alive
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9
1,CLOSED
1,CONNECT
Host: 192.168.4.1
fari/537.36
37.36 (KHTMLET /AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAhange;v=b3;q=0.7
Accepcation/xhtmlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADDAAAAAAAAAAAAAt-Encoding: gzip, deflate
Accep9
e: en-US,en;q=0.te
Accept-lAA1,CLOSED
1,CONNECT
Hte
Accept-lAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADDAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAost: 192.168.4.1
Cction: keep-alive
Upgrae-Insecure-Requests: 1
User-Ari/537.36
Accept: text
User-Agen-lAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=0.7
Accepq,applicatio+xml,appliclAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADDAAAAAAAAAAAAAt-Encoding: gzip, deflate
Accepanguage: en-US,en;q=0.9
cept-LAA1,CLOSED
You can clearely see that 3'rd data is corrupted. there is no +ipd AND EVEN DATA is kind of mixedup and corrupted.
esp-at
Re: ESP32-C3-WROOM-02 AT FIRMWARE +IPD WRONG DATA
Postby esp-at » Mon Apr 01, 2024 9:16 am
could you please pull the latest master code, and enable the logs, see what happened~
You can enable the logs by the following steps:
python build.py menuconfig -> Component config -> Log output -> Default log verbosity -> Info
python build.py menuconfig -> Component config -> AT -> Enable ESP-AT Debug -> Enable Network Debug as the attachment p1.png shows.
