Weight Scale on ESP32-C3 on Liliygo T-Zigbee Board
TinTin
Postby TinTin » Sat Jun 08, 2024 11:27 am
i'm trying to build an weight scale with with the Liliygo T-Zigbee Board using an HX711 and 4x 50kg weight cells. I get different reading on every calibation and the reading dont really change as expeced on adding or removing weights on the cells and the measurement drifts.
I have rewired it multiple times already to make sure there are no mistakes there. I changed the the DT and SCK Pin connection to other GPIO-Pins without success.
I don't really know what else could be wrong. Could someone take a look and give me advice what i should change to get correct measurement and calibation.
The HX711 and the loadcells are wired like this
HX711 wiring.PNG (20.05 KiB) Viewed 2484 times
The HX711 is currently connected to the board as follows
GND -> GND
DT -> GPIO08
SCK -> GPIO06
VCC-> 3.3V
And The Pins on the board are like this
This is my current code
Code: Untitled.cpp Select all
#include <Arduino.h>
#include "HX711.h"
#include "soc/rtc.h"
HX711 scale;
uint8_t dataPin = 8;
uint8_t clockPin = 6;
void setup()
delay(2000);
Serial.println();
rtc_cpu_freq_config_t config;
rtc_clk_cpu_freq_get_config(&config);
rtc_clk_cpu_freq_mhz_to_config(80, &config);
rtc_clk_cpu_freq_set_config_fast(&config);
scale.begin(dataPin, clockPin);
delay(2000);
Serial.print("UNITS: ");
Serial.println(scale.get_units(10));
Serial.println("\nEmpty the scale, press a key to continue");
while(!Serial.available());
while(Serial.available())
Serial.read();
delay(5000);
scale.tare();
Serial.println("\nPut 1000 gram in the scale, press a key to continue");
while(Serial.available()) Serial.read();
delay(5000);
scale.calibrate_scale(1000, 5);
Serial.println("\nScale is calibrated, press a key to continue");
Serial.print("Scale:");
Serial.println(scale.get_scale());
Serial.print("OFFSET:");
Serial.println(scale.get_offset());
Serial.println("");
Serial.println("");
Serial.println("");
Serial.print("UNIT");
Serial.print("\t;");
Serial.print("VALUE");
Serial.println("READ");
void loop()
long UNIT = scale.get_units(1);
long VALUE = scale.get_value(1);
long READ = scale.read();
Serial.print(UNIT);
Serial.print(VALUE);
Serial.println(READ);
The output and measurement i get while an 1000g wheight is on the scale is as follows
Code: Untitled.txt Select all
UNITS: -158241.80
UNITS: -111.80
UNITS: 13139.30
Scale:-0.01
OFFSET:-158227
UNIT ;VALUE ;READ
3610 ;-81 ;-158274
802 ;-62 ;-158252
-401 ;28 ;-158202
4312 ;-45 ;-158268
200 ;12 ;-158177
-4312 ;14 ;-158238
2607 ;-43 ;-158222
2908 ;-37 ;-158332
17953 ;-106 ;-158299
17151 ;-174 ;-158385
14242 ;-168 ;-158421
17351 ;-242 ;-158470
16750 ;-132 ;-158338
14142 ;-172 ;-158376
16449 ;-118 ;-158285
6018 ;-135 ;-158279
7622 ;-78 ;-158302
11033 ;-102 ;-158320
9929 ;-59 ;-158316
12236 ;-111 ;-158337
5416 ;-72 ;-158386
9227 ;-75 ;-158308
8625 ;-140 ;-158386
12938 ;-129 ;-158337
11534 ;-168 ;-158348
5616 ;-20 ;-158273
8425 ;-100 ;-158285
-200 ;18 ;-158138
-9929 ;101 ;-158131
-9628 ;143 ;-158042
-23269 ;201 ;-158004
-28886 ;216 ;-158027
-18856 ;138 ;-158130
-20260 ;240 ;-157978
-20461 ;182 ;-157996
-23169 ;203 ;-158000
-26579 ;218 ;-158048
-15145 ;143 ;-158126
-7422 ;55 ;-158172
-3510 ;27 ;-158168
-1705 ;14 ;-158158
-7923 ;23 ;-158220
-13640 ;196 ;-158122
-9829 ;139 ;-158056
-22868 ;208 ;-157940
-27983 ;300 ;-157925
-30290 ;324 ;-157839
-29989 ;312 ;-157896
-30992 ;344 ;-157852
-42326 ;429 ;-157781
-37512 ;428 ;-157762
-51052 ;572 ;-157584
-67401 ;648 ;-157559
-58575 ;615 ;-157517
-71413 ;753 ;-157297
-100199 ;1140 ;-156859
-143529 ;1442 ;-156896
-115345 ;1492 ;-156586
-174020 ;1796 ;-156508
-165795 ;1656 ;-156583
-168403 ;1603 ;-156698
-163087 ;1692 ;-156439
-191071 ;1813 ;-156463
-188664 ;1924 ;-156416
-186959 ;1918 ;-156285
-191974 ;1949 ;-156324
-196487 ;1967 ;-156212
-188664 ;1888 ;-156339
-189065 ;1716 ;-156582
-170911 ;1807 ;-156363
-188664 ;1764 ;-156469
-172917 ;1614 ;-156439
-177330 ;1786 ;-156329
-186758 ;1879 ;-156348
-181843 ;1852 ;-156272
-201903 ;2022 ;-156291
-186457 ;1906 ;-156305
-195384 ;1949 ;-156247
-205815 ;2055 ;-156194
-208022 ;2161 ;-156053
-216748 ;2162 ;-156046
-217751 ;2211 ;-156015
-215745 ;2114 ;-156146
-206517 ;2056 ;-156148
-210329 ;2051 ;-156154
-208924 ;2053 ;-156172
-211933 ;2099 ;-156065
-215444 ;2154 ;-156108
-212134 ;2121 ;-156080
-218453 ;2073 ;-156133
-212435 ;2153 ;-156141
-207119 ;2081 ;-156161
-206216 ;2008 ;-156190
-207420 ;2089 ;-156121
-225073 ;2337 ;-155858
-239115 ;2385 ;-155800
-244130 ;2417 ;-155906
-227179 ;2315 ;-155817
-240920 ;2365 ;-155895
-232796 ;2356 ;-155859
-245333 ;2447 ;-155844
-242525 ;2524 ;-155715
-249546 ;2452 ;-155820
-242324 ;2371 ;-155911
-228383 ;2198 ;-155964
-229386 ;2230 ;-155975
-229787 ;2317 ;-155926
-228182 ;2289 ;-155943
-233498 ;2297 ;-155943
-236407 ;2391 ;-155815
-244631 ;2395 ;-155768
-249747 ;2475 ;-155769
-246637 ;2490 ;-155770
-249646 ;2575 ;-155574
-264992 ;2593 ;-155646
-257169 ;2617 ;-155559
-272314 ;2711 ;-155452
-280037 ;2767 ;-155505
-279837 ;2751 ;-155475
-275624 ;2719 ;-155484
-276125 ;2690 ;-155560
-266798 ;2676 ;-155502
-267801 ;2660 ;-155514
-262485 ;2603 ;-155604
-263889 ;2623 ;-155573
-272414 ;2578 ;-155673
-257068 ;2616 ;-155580
-263287 ;2605 ;-155621
-261883 ;2625 ;-155646
-252354 ;2523 ;-155655
-250750 ;2469 ;-155783
-250148 ;2473 ;-155666
-262986 ;2624 ;-155693
-251251 ;2576 ;-155712
-246336 ;2485 ;-155752
-250649 ;2446 ;-155828
-246035 ;2438 ;-155906
-240720 ;2419 ;-155903
-233899 ;2383 ;-155881
-235103 ;2393 ;-155909
-237410 ;2412 ;-155823
-239215 ;2307 ;-155926
-240419 ;2341 ;-155843
-244732 ;2434 ;-155809
-245133 ;2529 ;-155696
-257670 ;2536 ;-155753
-251753 ;2531 ;-155716
-250850 ;2510 ;-155714
-257369 ;2543 ;-155731
-241221 ;2340 ;-155793
-250047 ;2439 ;-155792
lbernstone
Re: Weight Scale on ESP32-C3 on Liliygo T-Zigbee Board
Postby lbernstone » Sun Jun 09, 2024 6:13 pm
You should read the HX711 datasheet. I don't think it works the way you are thinking- it is intended to be a differential reading between two poles on a strain sensor, and provide 2 such inputs. If you just want to read multiple analog inputs, the esp32 can do that directly, or you can get a device like ADS1115.
https://cdn.sparkfun.com/datasheets/Sen ... nglish.pdf
TinTin
Postby TinTin » Mon Jun 10, 2024 8:53 am
Hello lbernstone,
yes i know that. Thats the reason the 4 halfbridge weight cells are forming a Wheatstone bridge so that on applying pressure on them the resistances change and the voltages on the inputs A+ and A- change accordingly. And the HX711 should amplify that input signal.
I took this as example for my setup
https://randomnerdtutorials.com/esp32-load-cell-hx711/
the difference to my setup there is that i use 4 halfbridge weight cells to form a full bridge weight cell and they use a different board. But it still uses an esp32 in that board.
And there are multiple setups there they use the same loadcells with the hx711 and the same wiring of the loadcells to the hx711 but instead with an arduino board and it works.
So i dont think I'm wrong in that part.
What i suspect is that maybe the internal ADC of the board trys to convert an alredy digital input. But that should not be it because i changed the pins to which the hx711 is connected to board.
Or its something i'm just to blind to see.
eeseboi
Postby eeseboi » Wed Jan 14, 2026 6:01 am
Any updates? I have the exact same issue. Most answers revolve around just using a full-bridge load cell vs the half-bridge + combinator.
