What is the junction temperature of ESP32-S3?
june001
Postby june001 » Fri Dec 13, 2024 3:11 am
From the datasheet, it shows the ambient temperature is -40 to 85 °C, but High Temperature Operating Life test is 125°C(Max). So, what is the junction temperature of ESP32-S3?
ESP_mofeifei
Re: What is the junction temperature of ESP32-S3?
Postby ESP_mofeifei » Fri Dec 13, 2024 8:20 am
Hi, the ESP32-S3's maximum junction temperature is 125°C. However, in actual use, the junction temperature can be lower due to flash and PSRAM packaging.
MattiaBerton
Postby MattiaBerton » Thu May 21, 2026 11:38 am
Since ESP32-S3-MINI-1-N8 has a max of 85°C, does it mean that internal temperature of the device measured with its own peripheral can't go over 85°C? Is it the flash chip that prevents reaching higher temperatures?
Users browsing this forum: Amazon [Bot], Applebot and 2 guests
