How i can disable automatic CS from SPI
BugSimpson
Postby BugSimpson » Mon Dec 23, 2024 6:13 pm
good evenig,
i use a c3 in spi master mode.
which register must be write to handle the cs pin by my self?
i have try to disable the mapping for FSPICS0 but i become a cs from about 40ns (see picture)
thx
username
Re: How i can disable automatic CS from SPI
Postby username » Tue Dec 24, 2024 6:46 pm
.spics_io_num = -1, // GPIO pin for CS signal, or -1 if not used.
BugSimpson
Postby BugSimpson » Wed Dec 25, 2024 9:15 am
I dont use the framework.
I want to now how I can do this with Register…
ok-home
Contact:
Postby ok-home » Wed Dec 25, 2024 12:06 pm
watch TRM
disable in spi registers
esp32c3 trm
or do not connect in gpio iomux/matrix
or set gpio level to 1
gpio_reset_pin(CS);
gpio_set_direction(CS,GPIO_MODE_OUTPUT);
gpio_set_level(CS,1);
BugSimpson
Postby BugSimpson » Wed Dec 25, 2024 6:39 pm
i allready have try this, have you seen my picture in #1?
there you can see short spikes.. i dont no why^^
ok-home
Contact:
Postby ok-home » Wed Dec 25, 2024 11:00 pm
if you get this picture after this
#define CS 1
gpio_reset_pin(CS);
gpio_set_level(CS,0);
look for external sources of interference
this code completely disables all interfaces and sets logic 0 on the CS output (GPIO1).
Users browsing this forum: Semrush [Bot] and 1 guest
