Failed to load code into Esp32P4 device
Vineethad
Postby Vineethad » Sat Dec 28, 2024 6:48 am
I have started working with the ESP32P4-Function-EV Board, and the IDE being used is Espressif IDE (v5.3.1). I successfully created and built the project, but when I attempted to flash the code into the ESP32P4 device, it displayed the following error:
Please help me to solve this problem.
Regards,
D.Vineetha.
Screenshot 2024-12-28 121550.png (147.89 KiB) Viewed 1156 times
Screenshot 2024-12-28 120829.png (62.51 KiB) Viewed 1156 times
Demirug
Re: Failed to load code into Esp32P4 device
Postby Demirug » Sat Dec 28, 2024 9:57 am
Based on the output your devkit has already V1.0 of the ESP32-P4. My understanding is that you need at least IDF 5.3.2 for this chip revision to work.
Vineethad
Postby Vineethad » Mon Dec 30, 2024 6:06 am
Thanks for the quick response,
I resolved the previous problem. Now I am facing another issue with debugging. When I start debugging, it shows the following error.
Regards,
D. Vineetha
Vineethad
Postby Vineethad » Mon Dec 30, 2024 9:35 am
This debug log:
Screenshot 2024-12-30 112620.png (147.05 KiB) Viewed 941 times
Vineethad
Postby Vineethad » Mon Dec 30, 2024 9:39 am
This is the debug log:
Screenshot 2024-12-30 121819.png (94.37 KiB) Viewed 941 times
