ESP32 C3 mini not programming
Barczi
Postby Barczi » Sun Mar 09, 2025 5:21 pm
I have a custom esp32 c3 mini board and I was programming it and using it. Suddenly it stopped programming. It always shows on the same COM port, when I try to upload program it gets stuck on "Connecting...", then it shows:
"A fatal error occurred: No serial data received."
Nothing changed between failed and successful upload.
Re: ESP32 C3 mini not programming
Postby Sprite » Mon Mar 10, 2025 2:04 am
Hard to say, you're not giving many details. Can you post at least the schematics of your board? What was the last firmware you programmed into it supposed to do? What OS and Arduino version are you using? Are you forcing the C3 into bootloader mode in some way?
Barczi
Postby Barczi » Mon Mar 10, 2025 7:31 pm
Before use I forced the board to go into the bootloader and then solder it on the board forgot to add IO8 pin on the board, so forcing it again means desoldering module (which I can do, if necessary). There is no RC delay circuit on enable (never needed it).
This is code after which it all broke:
#include <BleKeyboard.h>
BleKeyboard bleKeyboard("Media-control", "Barczi", 100);
#define backlight 0
#define battlvl 2
#define chargerswitch 3
#define back 10
#define voldown 1
#define pause 6
#define volup 5
#define next 4
  bleKeyboard.begin();
  pinMode(backlight, OUTPUT);
  pinMode(back, INPUT);
  pinMode(voldown, INPUT);
  pinMode(pause, INPUT);
  pinMode(volup, INPUT);
  pinMode(next, INPUT);
  if(digitalRead(back)==LOW){
    Serial.println("back");
    blink(500);
  if(digitalRead(voldown)==LOW){
    Serial.println("voldown");
    blink(500);
  if(digitalRead(pause)==LOW){
    Serial.println("pause");
    blink(500);
  if(digitalRead(volup)==LOW){
    Serial.println("volup");
    blink(500);
  if(digitalRead(next)==LOW){
    Serial.println("next");
    blink(500);
void blink(int intervol){
  digitalWrite(backlight, HIGH);
  delay(intervol);
  digitalWrite(backlight, LOW);
And this is a image of important part of schematic.
Zrzut ekranu 2025-03-10 202751.png (61.77 KiB) Viewed 1132 times
lbernstone
Postby lbernstone » Mon Mar 10, 2025 9:34 pm
If you don't follow the hardware design guidelines, then your behavior may not be reliable. In addition to the RC timing circuit, you should have gpio8 pulled up, and 5.1k resistors pulled down on usb cc1 & cc2.
Users browsing this forum: PerplexityBot, Qwantbot and 1 guest
