ESP32-C5-WROOM-1 Top Layer and 4 layer PCB layout
Panometric
Postby Panometric » Fri Jun 13, 2025 4:26 pm
I need some clarification on PCB design requirement for ESP32-C5-WROOM-1:
In the 2D download: https://www.espressif.com/sites/defaul ... rint_0.dxf there is a unusual declared "No GND copper only in top layer"
Yet, in the device datasheet: https://www.espressif.com/sites/default ... eet_en.pdf Section 11.1 and 11.2 does not mention this area, nor does https://docs.espressif.com/projects/esp ... esign.html
In the dev board https://dl.espressif.com/dl/schematics/ ... 250211.pdf it shows a gap in the top layer copper. but the bottom layer does have a GND pour in that area.
1. Which document is correct?
2. For a 4 layer board where layer 2 is solid GND and 7.8 mil away from top, is it OK to leave GND on layer 2?
3. IF NOT, Is it OK to locate components on the bottom in this area?
4. Should the thermal vias on the Top be connected only to top copper, or also to GND on 2?
LJH
Re: ESP32-C5-WROOM-1 Top Layer and 4 layer PCB layout
Postby LJH » Thu Jun 19, 2025 8:14 am
Please refer to the latest datasheet, we will update DXF file.
Panometric
Postby Panometric » Mon Jun 23, 2025 7:42 pm
Thank you but Datasheet Pre-release v0.5 does not show the PCB layout at all so it's unclear.
@LJH Are all these answers correct?
Datasheet - ignore declaration of this area on dxf
Yes, GND under any area that is not antenna is OK
Yes, because GND area is almost continuous
Connect 9 center pads to GND net, top and any other layer.
Users browsing this forum: Bing [Bot] and 6 guests
