Can't Enable GCOV in VSCode
kozmotronik
Postby kozmotronik » Tue Jul 08, 2025 11:11 am
I've tried to enable code coverage for unit testing in many ways but with no success. I follow instructions from https://docs.espressif.com/projects/vsc ... f-coverage page.
According to this guide I need to execute the following command to enable apptracing and gcov:
ESP-IDF: Configure Project SDKConfig for Coverage
. When I execute it I get the following output:
{"version": 2, "set": { "APPTRACE_DEST_TRAX": true, "APPTRACE_GCOV_ENABLE": true }}
{"version":2,"save":"/disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig"}
---------------------------ERROR--------------------------
Error: The following config symbol(s) were not found: APPTRACE_DEST_TRAX, APPTRACE_GCOV_ENABLE
-----------------------END OF ERROR-----------------------
{"version": 2, "values": {}, "ranges": {}, "visible": {}, "error": ["The following config symbol(s) were not found: APPTRACE_DEST_TRAX, APPTRACE_GCOV_ENABLE"]}
Saving config to /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig...
{"version": 2, "values": {}, "ranges": {}, "visible": {}}
And a popup shows me this message:
Your project sdkconfig has been configured. Make sure to compile the source file with the --coverage option.
Then I've tried to set them manually in SDK Config interface, but nothing exists below the Component config about Application Level Tracing.
I've also tried with the idf.py menuconfig command, searched for apptrace options but found nothing about.
I really can't see those config symbols neither in the SDK Config interface nor in the sdkconfig file itself. Ain't those symbols should be generated automatically by Kconfig? How do I enable gcov for code coverage in this case?
It is a test app that implement unit tests on a custom component I develop. What is the key thing that I am missing? Is it something has to do with cmake configuration? Thank you.
For reference, here is some information about my setup:
OS: Linux
ESP-IDF SDK version: 5.4.2
Project repo: https://git.kozmotronik.com.tr/Kozmotro ... /test_apps
kozmotronik
Re: Can't Enable GCOV in VSCode
Postby kozmotronik » Tue Jul 08, 2025 11:57 am
I've tried adding the path of the app_trace as IDF_PATH/components as below but didn't work.
I've also tried adding those config symbols to a sdkconfig.defaults file as below:
# For IDF 5.0
CONFIG_ESP_TASK_WDT_EN=n
# For IDF4.4
CONFIG_ESP_TASK_WDT=n
CONFIG_APPTRACE_DEST_UART=y
# CONFIG_APPTRACE_DEST_NONE is not set
CONFIG_APPTRACE_ENABLE=y
CONFIG_APPTRACE_LOCK_ENABLE=y
CONFIG_APPTRACE_ONPANIC_HOST_FLUSH_TMO=-1
CONFIG_APPTRACE_POSTMORTEM_FLUSH_THRESH=0
CONFIG_APPTRACE_PENDING_DATA_SIZE_MAX=0
CONFIG_APPTRACE_GCOV_ENABLE=y
But when I clean and reopen the SDK Config UI I get the following output:
Loading defaults file /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults...
/disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults:5 CONFIG_ESP_TASK_WDT was replaced with CONFIG_ESP_TASK_WDT_INIT
warning: unknown kconfig symbol 'APPTRACE_DEST_UART' assigned to 'y' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
warning: unknown kconfig symbol 'APPTRACE_DEST_NONE' assigned to 'n' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
warning: unknown kconfig symbol 'APPTRACE_ENABLE' assigned to 'y' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
warning: unknown kconfig symbol 'APPTRACE_LOCK_ENABLE' assigned to 'y' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
warning: unknown kconfig symbol 'APPTRACE_ONPANIC_HOST_FLUSH_TMO' assigned to '-1' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
warning: unknown kconfig symbol 'APPTRACE_POSTMORTEM_FLUSH_THRESH' assigned to '0' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
warning: unknown kconfig symbol 'APPTRACE_PENDING_DATA_SIZE_MAX' assigned to '0' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
warning: unknown kconfig symbol 'APPTRACE_GCOV_ENABLE' assigned to 'y' in /disk/Projeler/ESP-Components/relay_chn/test_apps/sdkconfig.defaults
Are those symbols deprecated or what?
bignacio
Postby bignacio » Thu Jul 17, 2025 4:32 am
I think there is an issue with your project configuration.
please review the Code coverage example https://github.com/espressif/esp-idf/tr ... ystem/gcov
kozmotronik
Postby kozmotronik » Thu Jul 24, 2025 8:07 am
Hi @bignacio,
Thanks for the answer, but the example does not help to solve the problem.
It turns out that this problem arises because the ESP-IDF can't find the configuration of the app_trace component. Although this wasn't mentioned in the relevant docs or the gcov example, the component should be declared in the test_app/main/CMakeLists.txt file as a REQUIRED component.
idf_component_register(
    SRCS ${srcs}
    INCLUDE_DIRS "."
    REQUIRES unity relay_chn app_trace
    WHOLE_ARCHIVE
