Need Support for ESP-IDF Setup with LVGL.
Hiten Shah
Postby Hiten Shah » Wed Jun 17, 2026 7:46 am
Good Day!
We are currently migrating our GUI development from Arduino to ESP-IDF based on recommendations received on the forum. We are using LVGL as our GUI library.
We require some support in setting up the ESP-IDF environment. We also tried contacting our local technical support, but unfortunately, we have not received any response.
Currently, we are facing the following issue:
- In menuconfig, the arrow keys are not working for navigation and selection.
- VS Code Version: 1.116.0
- ESP-IDF Version: 5.5.4
- GUI Library: LVGL
Could anyone please help us understand if there are any additional settings or dependencies required? Any guidance or suggestions would be greatly appreciated.
Thank you in advance for your support.
Best Regards
Re: Need Support for ESP-IDF Setup with LVGL.
Postby Sprite » Thu Jun 18, 2026 12:10 am
Moved ESP32-S31 -> IDE support, as the arrow key problem likely is a VSCode issue.
bignacio
Postby bignacio » Wed Jun 24, 2026 9:18 am
Hi @Hiten Shah
How are you launching menuconfig? Are you using our VS Code Extension for ESP-IDF ?
If you are, please try our latest master vsix installer as we made some bugfix related to this. You can use this VSIX to test the current github master of the extension by pressing F1 or click menu View -> Command Palette..., type Install from VSIX and then select the previously downloaded .vsix file to install the extension.
If you are not, how are you configuring the VS Code for ESP-IDF ?
Hiten Shah
Postby Hiten Shah » Thu Jun 25, 2026 11:06 am
Thanks for your response.
we use visual studio with espidf extension.
As per your guide line, we install VSIX in my VS code using install from VSIX command. it install success but when i enter "idf.py menuconfig" in terminal then menuconfig blue color window open but my arrow key still not work to navigate.
kondalkolipaka
Postby kondalkolipaka » Mon Jun 29, 2026 6:18 am
It could be a terminal specific issue https://github.com/espressif/vscode-esp ... n/issues/6, we will check that.
However, esp-idf vscode extension offers "ESP-IDF: SDK Configuration Editor" command to launch the menuconfig, please check if that helps?
Screenshot 2026-06-29 at 11.48.10 AM.png (414.03 KiB) Viewed 81 times
username
Postby username » Tue Jun 30, 2026 9:26 pm
Just click that little gear icon next to the garbage can to open menuconfig.
Hiten Shah
Postby Hiten Shah » Wed Jul 01, 2026 3:32 am
Yes, this "ESP-IDF: SDK Configuration Editor" work in our laptop. we use this for configuration still. if any terminal related issue solved then please inform us.
Thanks.
