Hi Espressif Systems Developer,
We have started to use ESP32 SoC as well as ESP32 based modules into different product which are running successfully.
Now, I have one question like what is the default state of unused GPIO or IO pads into module itself?
Let's take one example like there is one IO3 which I haven't used into my product then what will be the default state means HIGH or LOW and input or output direction.
So, I just want to get I formation regard that so that I need to configure it from software side if state is tristate or not fixed
Need help to get default state of unused IO pads for ESP32 modules
Re: Need help to get default state of unused IO pads for ESP32 modules
Look at datasheet appendix A you can see that io3 has input mode with weak pull-up and default function is u0rxd
Thanks for Reply.Look at datasheet appendix A you can see that io3 has input mode with weak pull-up and default function is u0rxd
I will check and will let you know if any query regarding that.
Regards,
Ritesh Prajapati
Ritesh Prajapati
Users browsing this forum: Baidu [Spider] and 5 guests
