ESP32 reads BLE iTag's Battery Service
borch84
Postby borch84 » Fri May 04, 2018 9:40 pm
Hello, I am using gatt client example for reading the battery level value from an Itag, which is a BLE device.
The device is:
Screen Shot 2018-05-04 at 15.17.28.png (558.12 KiB) Viewed 8667 times
I am using the nRF Connect to discover the services advertised by the iTag. As you can see, the battery service is reporting 99%
WhatsApp Image 2018-05-04 at 3.08.24 PM.jpeg (82.73 KiB) Viewed 8667 times
I have modified the gatt client code to read the service UUID from the itag.
#define REMOTE_SERVICE_UUID        0x180F //iTAG battery service
#define REMOTE_NOTIFY_CHAR_UUID    0x2A19 //battery level characteristic
I found that when the esp_ble_gattc_register_for_notify funcion is called, it return 0 (cero) descriptor for the characteristic. Instead of calling for esp_ble_gattc_register_for_notify, I call instead esp_ble_gattc_read_char.
When the read funcion happens, it calls the ESP_GATTC_READ_CHAR_EVT:
    case ESP_GATTC_READ_CHAR_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_READ_CHAR_EVT");
        ESP_LOGI(GATTC_TAG, "p_data->read.value %s",p_data->read.value);
        ESP_LOGI(GATTC_TAG, "p_data->read.value_len %d",p_data->read.value_len);
When this part of code executes it returns the following values:
I (604) GATTC_DEMO: remote_device_name: iTAG | remote_device_name len: 4
I (604) GATTC_DEMO: adv_name_nospaces: iTAG | adv_name_nospaces len: 4
I (614) GATTC_DEMO: searched device iTAG
I (614) GATTC_DEMO: connect to the remote device.
I (624) GATTC_DEMO: stop scan successfully
I (1244) GATTC_DEMO: ESP_GATTC_CONNECT_EVT conn_id 0, if 3
I (1244) GATTC_DEMO: REMOTE BDA:
I (1244) GATTC_DEMO: ff ff c1 00 ad 3e
I (1254) GATTC_DEMO: open success
I (1724) GATTC_DEMO: ESP_GATTC_CFG_MTU_EVT, Status 0, MTU 23, conn_id 0
I (1724) GATTC_DEMO: ESP_GATTC_SEARCH_RES_EVT
I (1724) GATTC_DEMO: service found
I (1734) GATTC_DEMO: UUID16: 180f
I (1734) GATTC_DEMO: ESP_GATTC_SEARCH_CMPL_EVT
I (1744) GATTC_DEMO: attr count: 1
I (1744) GATTC_DEMO: char count: 1
I (1774) GATTC_DEMO: ESP_GATTC_READ_CHAR_EVT
I (1774) GATTC_DEMO: p_data->read.value c
I (1774) GATTC_DEMO: p_data->read.value_len 1
I am confused because I think it should return "99%", am I correct?
Maybe somebody has a better understanding of this and could point me to the correct direction. My objective is to be able to read the value "99%" from the ESP32. Thank you.
I am using the following code:
* This file is for gatt client. It can scan ble device, connect one device.
* Run the gatt_server demo, the client demo will automatically connect to the gatt_server demo.
* Client demo will enable gatt_server's notify after connection. Then the two devices will exchange
* data.
#ifndef BTM_INITIAL_TRACE_LEVEL
#define BTM_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#ifndef L2CAP_INITIAL_TRACE_LEVEL
#define L2CAP_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#ifndef GATT_INITIAL_TRACE_LEVEL
#define GATT_INITIAL_TRACE_LEVEL BT_TRACE_LEVEL_DEBUG
#endif
#include <stdint.h>
#include <string.h>
#include <stdbool.h>
#include <stdio.h>
#include "nvs.h"
#include "nvs_flash.h"
#include "controller.h"
#include "esp_bt.h"
#include "esp_gap_ble_api.h"
#include "esp_gattc_api.h"
#include "esp_gatt_defs.h"
#include "esp_bt_main.h"
#include "esp_gatt_common_api.h"
#define GATTC_TAG "GATTC_DEMO"
#define PROFILE_NUM      1
#define PROFILE_A_APP_ID 0
#define INVALID_HANDLE   0
//static const char remote_device_name[] = "ESP_GATTS_DEMO";
static const char remote_device_name[] = "iTAG"; //borch
static bool connect    = false;
static bool get_server = false;
static esp_gattc_char_elem_t *char_elem_result   = NULL;
static esp_gattc_descr_elem_t *descr_elem_result = NULL;
/* eclare static functions */
static void esp_gap_cb(esp_gap_ble_cb_event_t event, esp_ble_gap_cb_param_t *param);
static void esp_gattc_cb(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if, esp_ble_gattc_cb_param_t *param);
static void gattc_profile_event_handler(esp_gattc_cb_event_t event, esp_gatt_if_t gattc_if, esp_ble_gattc_cb_param_t *param);
static esp_bt_uuid_t remote_filter_service_uuid = {
    .len = ESP_UUID_LEN_16,
    .uuid = {.uuid16 = REMOTE_SERVICE_UUID,},
static esp_bt_uuid_t remote_filter_char_uuid = {
    .uuid = {.uuid16 = REMOTE_NOTIFY_CHAR_UUID,},
static esp_bt_uuid_t notify_descr_uuid = {
    .uuid = {.uuid16 = ESP_GATT_UUID_CHAR_CLIENT_CONFIG,},
static esp_ble_scan_params_t ble_scan_params = {
    .scan_type              = BLE_SCAN_TYPE_ACTIVE,
    .own_addr_type          = BLE_ADDR_TYPE_PUBLIC,
    .scan_filter_policy     = BLE_SCAN_FILTER_ALLOW_ALL,
    .scan_interval          = 0x50,
    .scan_window            = 0x30
struct gattc_profile_inst {
    esp_gattc_cb_t gattc_cb;
    uint16_t gattc_if;
    uint16_t app_id;
    uint16_t conn_id;
    uint16_t service_start_handle;
    uint16_t service_end_handle;
    uint16_t char_handle;
    esp_bd_addr_t remote_bda;
/* One gatt-based profile one app_id and one gattc_if, this array will store the gattc_if returned by ESP_GATTS_REG_EVT */
static struct gattc_profile_inst gl_profile_tab[PROFILE_NUM] = {
    [PROFILE_A_APP_ID] = {
        .gattc_cb = gattc_profile_event_handler,
        .gattc_if = ESP_GATT_IF_NONE,       /* Not get the gatt_if, so initial is ESP_GATT_IF_NONE */
    esp_ble_gattc_cb_param_t *p_data = (esp_ble_gattc_cb_param_t *)param;
    switch (event) {
    case ESP_GATTC_REG_EVT:
        ESP_LOGI(GATTC_TAG, "REG_EVT");
        esp_err_t scan_ret = esp_ble_gap_set_scan_params(&ble_scan_params);
        if (scan_ret){
            ESP_LOGE(GATTC_TAG, "set scan params error, error code = %x", scan_ret);
    case ESP_GATTC_CONNECT_EVT:{
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_CONNECT_EVT conn_id %d, if %d", p_data->connect.conn_id, gattc_if);
        gl_profile_tab[PROFILE_A_APP_ID].conn_id = p_data->connect.conn_id;
        memcpy(gl_profile_tab[PROFILE_A_APP_ID].remote_bda, p_data->connect.remote_bda, sizeof(esp_bd_addr_t));
        ESP_LOGI(GATTC_TAG, "REMOTE BDA:");
        esp_log_buffer_hex(GATTC_TAG, gl_profile_tab[PROFILE_A_APP_ID].remote_bda, sizeof(esp_bd_addr_t));
        esp_err_t mtu_ret = esp_ble_gattc_send_mtu_req (gattc_if, p_data->connect.conn_id);
        if (mtu_ret){
            ESP_LOGE(GATTC_TAG, "config MTU error, error code = %x", mtu_ret);
    case ESP_GATTC_OPEN_EVT:
        if (param->open.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "open failed, status %d", p_data->open.status);
        ESP_LOGI(GATTC_TAG, "open success");
    case ESP_GATTC_CFG_MTU_EVT:
        if (param->cfg_mtu.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG,"config mtu failed, error status = %x", param->cfg_mtu.status);
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_CFG_MTU_EVT, Status %d, MTU %d, conn_id %d", param->cfg_mtu.status, param->cfg_mtu.mtu, param->cfg_mtu.conn_id);
        esp_ble_gattc_search_service(gattc_if, param->cfg_mtu.conn_id, &remote_filter_service_uuid);
    case ESP_GATTC_SEARCH_RES_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SEARCH_RES_EVT");
        esp_gatt_srvc_id_t *srvc_id =(esp_gatt_srvc_id_t *)&p_data->search_res.srvc_id;
        if (srvc_id->id.uuid.len == ESP_UUID_LEN_16 && srvc_id->id.uuid.uuid.uuid16 == REMOTE_SERVICE_UUID) {
            ESP_LOGI(GATTC_TAG, "service found");
            get_server = true;
            gl_profile_tab[PROFILE_A_APP_ID].service_start_handle = p_data->search_res.start_handle;
            gl_profile_tab[PROFILE_A_APP_ID].service_end_handle = p_data->search_res.end_handle;
            ESP_LOGI(GATTC_TAG, "UUID16: %x", srvc_id->id.uuid.uuid.uuid16);
    case ESP_GATTC_SEARCH_CMPL_EVT:
        if (p_data->search_cmpl.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "search service failed, error status = %x", p_data->search_cmpl.status);
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SEARCH_CMPL_EVT");
        if (get_server){
            uint16_t count = 0;
            esp_gatt_status_t status = esp_ble_gattc_get_attr_count( gattc_if,
        p_data->search_cmpl.conn_id,
        ESP_GATT_DB_CHARACTERISTIC,
        gl_profile_tab[PROFILE_A_APP_ID].service_start_handle,
        gl_profile_tab[PROFILE_A_APP_ID].service_end_handle,
        INVALID_HANDLE,
        &count);
            if (status != ESP_GATT_OK){
                ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_attr_count error");
            ESP_LOGI(GATTC_TAG, "attr count: %d\n",count);
            if (count > 0){
                char_elem_result = (esp_gattc_char_elem_t *)malloc(sizeof(esp_gattc_char_elem_t) * count);
                if (!char_elem_result){
                    ESP_LOGE(GATTC_TAG, "gattc no mem");
                }else{
                    status = esp_ble_gattc_get_char_by_uuid( gattc_if,
                                                             remote_filter_char_uuid,
                                                             char_elem_result,
                                                             &count);
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_char_by_uuid error");
                    /*  Every service have only one char in our 'ESP_GATTS_DEMO' demo, so we used first 'char_elem_result' */
                    if (count > 0 && (char_elem_result[0].properties & ESP_GATT_CHAR_PROP_BIT_NOTIFY)){
                        ESP_LOGI(GATTC_TAG, "char count: %d\n",count);
                        gl_profile_tab[PROFILE_A_APP_ID].char_handle = char_elem_result[0].char_handle;
                        esp_ble_gattc_read_char(gattc_if,p_data->search_cmpl.conn_id,gl_profile_tab[PROFILE_A_APP_ID].char_handle,ESP_GATT_AUTH_REQ_NONE);
                        //esp_ble_gattc_register_for_notify (gattc_if, gl_profile_tab[PROFILE_A_APP_ID].remote_bda, char_elem_result[0].char_handle);
                /* free char_elem_result */
                free(char_elem_result);
            }else{
                ESP_LOGE(GATTC_TAG, "no char found");
    case ESP_GATTC_REG_FOR_NOTIFY_EVT: {
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_REG_FOR_NOTIFY_EVT");
        if (p_data->reg_for_notify.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "REG FOR NOTIFY failed: error status = %d", p_data->reg_for_notify.status);
        }else{
            uint16_t count = 0;
            uint16_t notify_en = 1;
            esp_gatt_status_t ret_status = esp_ble_gattc_get_attr_count( gattc_if,
        gl_profile_tab[PROFILE_A_APP_ID].conn_id,
        ESP_GATT_DB_DESCRIPTOR,
        &count);
            if (ret_status != ESP_GATT_OK){
            ESP_LOGI(GATTC_TAG, "desc count: %d\n",count);
            if (count > 0){
                descr_elem_result = malloc(sizeof(esp_gattc_descr_elem_t) * count);
                if (!descr_elem_result){
                    ESP_LOGE(GATTC_TAG, "malloc error, gattc no mem");
                }else{
                    ret_status = esp_ble_gattc_get_descr_by_char_handle( gattc_if,
        p_data->reg_for_notify.handle,
        notify_descr_uuid,
        descr_elem_result,
        &count);
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_get_descr_by_char_handle error");
                    /* Every char has only one descriptor in our 'ESP_GATTS_DEMO' demo, so we used first 'descr_elem_result' */
                    if (count > 0 && descr_elem_result[0].uuid.len == ESP_UUID_LEN_16 && descr_elem_result[0].uuid.uuid.uuid16 == ESP_GATT_UUID_CHAR_CLIENT_CONFIG){
                        ret_status = esp_ble_gattc_write_char_descr( gattc_if,
        descr_elem_result[0].handle,
        sizeof(notify_en),
        (uint8_t *)&notify_en,
        ESP_GATT_WRITE_TYPE_RSP,
                        ESP_LOGE(GATTC_TAG, "esp_ble_gattc_write_char_descr error");
                    /* free descr_elem_result */
                    free(descr_elem_result);
            else{
                ESP_LOGE(GATTC_TAG, "decsr not found");
    case ESP_GATTC_NOTIFY_EVT:
        if (p_data->notify.is_notify){
            ESP_LOGI(GATTC_TAG, "ESP_GATTC_NOTIFY_EVT, receive notify value:");
        }else{
            ESP_LOGI(GATTC_TAG, "ESP_GATTC_NOTIFY_EVT, receive indicate value:");
        esp_log_buffer_hex(GATTC_TAG, p_data->notify.value, p_data->notify.value_len);
    case ESP_GATTC_WRITE_DESCR_EVT:
        if (p_data->write.status != ESP_GATT_OK){
            ESP_LOGE(GATTC_TAG, "write descr failed, error status = %x", p_data->write.status);
        ESP_LOGI(GATTC_TAG, "write descr success ");
        uint8_t write_char_data[35];
        for (int i = 0; i < sizeof(write_char_data); ++i)
            write_char_data[i] = i % 256;
        esp_ble_gattc_write_char( gattc_if,
                                  sizeof(write_char_data),
                                  write_char_data,
    case ESP_GATTC_SRVC_CHG_EVT: {
        esp_bd_addr_t bda;
        memcpy(bda, p_data->srvc_chg.remote_bda, sizeof(esp_bd_addr_t));
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_SRVC_CHG_EVT, bd_addr:");
        esp_log_buffer_hex(GATTC_TAG, bda, sizeof(esp_bd_addr_t));
    case ESP_GATTC_WRITE_CHAR_EVT:
            ESP_LOGE(GATTC_TAG, "write char failed, error status = %x", p_data->write.status);
        ESP_LOGI(GATTC_TAG, "write char success ");
    case ESP_GATTC_DISCONNECT_EVT:
        connect = false;
        get_server = false;
        ESP_LOGI(GATTC_TAG, "ESP_GATTC_DISCONNECT_EVT, reason = %d", p_data->disconnect.reason);
    default:
    uint8_t *adv_name = NULL;
    uint8_t adv_name_len = 0;
    switch (event) {
    case ESP_GAP_BLE_SCAN_PARAM_SET_COMPLETE_EVT: {
        //the unit of the duration is second
        uint32_t duration = 30;
        esp_ble_gap_start_scanning(duration);
    case ESP_GAP_BLE_SCAN_START_COMPLETE_EVT:
        //scan start complete event to indicate scan start successfully or failed
        if (param->scan_start_cmpl.status != ESP_BT_STATUS_SUCCESS) {
            ESP_LOGE(GATTC_TAG, "scan start failed, error status = %x", param->scan_start_cmpl.status);
        ESP_LOGI(GATTC_TAG, "scan start success");
    case ESP_GAP_BLE_SCAN_RESULT_EVT: {
        esp_ble_gap_cb_param_t *scan_result = (esp_ble_gap_cb_param_t *)param;
        switch (scan_result->scan_rst.search_evt) {
        case ESP_GAP_SEARCH_INQ_RES_EVT:
            esp_log_buffer_hex(GATTC_TAG, scan_result->scan_rst.bda, 6);
            ESP_LOGI(GATTC_TAG, "searched Adv Data Len %d, Scan Response Len %d", scan_result->scan_rst.adv_data_len, scan_result->scan_rst.scan_rsp_len);
            adv_name = esp_ble_resolve_adv_data(scan_result->scan_rst.ble_adv,
                                                ESP_BLE_AD_TYPE_NAME_CMPL, &adv_name_len);
            ESP_LOGI(GATTC_TAG, "searched Device Name Len %d", adv_name_len);
            esp_log_buffer_char(GATTC_TAG, adv_name, adv_name_len);
            ESP_LOGI(GATTC_TAG, "\n");
            if (adv_name != NULL) {
                char adv_name_nospaces[strlen(remote_device_name)];
                int i,j;
                for ( i = 0, j = 0; i<strlen((const char*)adv_name);i++,j++) {
                    if (adv_name[i] != ' ')
                        adv_name_nospaces[j]=adv_name[i];
                    else
                        j--;
                adv_name_nospaces[j]=0;
                ESP_LOGI(GATTC_TAG, "remote_device_name: %s | remote_device_name len: %d\n", remote_device_name,strlen(remote_device_name));
                ESP_LOGI(GATTC_TAG, "adv_name_nospaces: %s | adv_name_nospaces len: %d\n", adv_name_nospaces,strlen(adv_name_nospaces));
                //if (strlen(remote_device_name) == adv_name_len && strncmp((char *)adv_name, remote_device_name, adv_name_len) == 0) {
                if ( strncmp(adv_name_nospaces, remote_device_name, strlen(adv_name_nospaces)) == 0 ) {
                    ESP_LOGI(GATTC_TAG, "searched device %s\n", remote_device_name);
                    if (connect == false) {
                        connect = true;
                        ESP_LOGI(GATTC_TAG, "connect to the remote device.");
                        esp_ble_gap_stop_scanning();
                        esp_ble_gattc_open(gl_profile_tab[PROFILE_A_APP_ID].gattc_if, scan_result->scan_rst.bda, scan_result->scan_rst.ble_addr_type, true);
        case ESP_GAP_SEARCH_INQ_CMPL_EVT:
        default:
    case ESP_GAP_BLE_SCAN_STOP_COMPLETE_EVT:
        if (param->scan_stop_cmpl.status != ESP_BT_STATUS_SUCCESS){
            ESP_LOGE(GATTC_TAG, "scan stop failed, error status = %x", param->scan_stop_cmpl.status);
        ESP_LOGI(GATTC_TAG, "stop scan successfully");
    case ESP_GAP_BLE_ADV_STOP_COMPLETE_EVT:
        if (param->adv_stop_cmpl.status != ESP_BT_STATUS_SUCCESS){
            ESP_LOGE(GATTC_TAG, "adv stop failed, error status = %x", param->adv_stop_cmpl.status);
        ESP_LOGI(GATTC_TAG, "stop adv successfully");
    case ESP_GAP_BLE_UPDATE_CONN_PARAMS_EVT:
         ESP_LOGI(GATTC_TAG, "update connection params status = %d, min_int = %d, max_int = %d,conn_int = %d,latency = %d, timeout = %d",
                  param->update_conn_params.status,
                  param->update_conn_params.min_int,
                  param->update_conn_params.max_int,
                  param->update_conn_params.conn_int,
                  param->update_conn_params.latency,
                  param->update_conn_params.timeout);
    default:
    /* If event is register event, store the gattc_if for each profile */
    if (event == ESP_GATTC_REG_EVT) {
        if (param->reg.status == ESP_GATT_OK) {
            gl_profile_tab[param->reg.app_id].gattc_if = gattc_if;
            ESP_LOGI(GATTC_TAG, "reg app failed, app_id %04x, status %d",
                    param->reg.app_id,
                    param->reg.status);
            return;
    /* If the gattc_if equal to profile A, call profile A cb handler,
     * so here call each profile's callback */
    do {
        int idx;
        for (idx = 0; idx < PROFILE_NUM; idx++) {
            if (gattc_if == ESP_GATT_IF_NONE || /* ESP_GATT_IF_NONE, not specify a certain gatt_if, need to call every profile cb function */
                    gattc_if == gl_profile_tab[idx].gattc_if) {
                if (gl_profile_tab[idx].gattc_cb) {
                    gl_profile_tab[idx].gattc_cb(event, gattc_if, param);
    } while (0);
void app_main()
    // Initialize NVS.
    if (ret == ESP_ERR_NVS_NO_FREE_PAGES) {
    ESP_ERROR_CHECK( ret );
    ESP_ERROR_CHECK(esp_bt_controller_mem_release(ESP_BT_MODE_CLASSIC_BT));
    esp_bt_controller_config_t bt_cfg = BT_CONTROLLER_INIT_CONFIG_DEFAULT();
    ret = esp_bt_controller_init(&bt_cfg);
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s initialize controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bt_controller_enable(ESP_BT_MODE_BLE);
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s enable controller failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_init();
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s init bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    ret = esp_bluedroid_enable();
    if (ret) {
        ESP_LOGE(GATTC_TAG, "%s enable bluetooth failed: %s\n", __func__, esp_err_to_name(ret));
        return;
    //register the  callback function to the gap module
    ret = esp_ble_gap_register_callback(esp_gap_cb);
    if (ret){
        ESP_LOGE(GATTC_TAG, "%s gap register failed, error code = %x\n", __func__, ret);
        return;
    //register the callback function to the gattc module
    ret = esp_ble_gattc_register_callback(esp_gattc_cb);
    if(ret){
        ESP_LOGE(GATTC_TAG, "%s gattc register failed, error code = %x\n", __func__, ret);
        return;
    ret = esp_ble_gattc_app_register(PROFILE_A_APP_ID);
    if (ret){
        ESP_LOGE(GATTC_TAG, "%s gattc app register failed, error code = %x\n", __func__, ret);
    esp_err_t local_mtu_ret = esp_ble_gatt_set_local_mtu(500);
    if (local_mtu_ret){
        ESP_LOGE(GATTC_TAG, "set local  MTU failed, error code = %x", local_mtu_ret);
cm6000
Re: ESP32 reads BLE iTag's Battery Service
Postby cm6000 » Thu May 10, 2018 6:27 am
I am trying to do similar thing although my remote devise is different. I have the UUIDs of the service and the characteristic but when the esp_ble_gattc_read_char is called on the ESP_GATTC_READ_CHAR_EVT the status is 1 which i think mean that the handle is invalid:
ESP_LOGI(GATTC_TAG, "READ CHAR EVT");
ESP_LOGI(GATTC_TAG, "p_data->read.status %d",p_data->read.status); //ESP_GATT_INVALID_HANDLE ???
Not sure what the "handle" should be - i am using the characteristic's UUID.
WiFive
Postby WiFive » Thu May 10, 2018 7:38 am
Not a string a uint8
99 = 0x63 = 'c'
borch84
Postby borch84 » Thu May 17, 2018 12:59 am
Thanks! I was able to read the value:
const char *char_pointer = (char*)p_data->read.value
int battery_percentage = (int)*char_pointer;
ESP_LOGI(GATTC_TAG, "(p_data->read.value) Battery level: %d %%",battery_percentage);
Users browsing this forum: Bing [Bot], ChatGPT-User and 1 guest
