Unable to program ESP32-SOLO-1
ajaykk
Postby ajaykk » Fri Oct 05, 2018 3:24 pm
I am unable to program ESP32-SOLO-1 using JTAG on the ESP-WROVER-KIT v3.
JTAG Connections:-
also, I enabled single core mode in menuconfig.
openocd output:-
$ ~/esp/openocd-esp32/bin/openocd -s ~/esp/openocd-esp32/share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg -c "program_esp32 build/hello-world.bin 0x10000 verify exit"
output:-
Open On-Chip Debugger 0.10.0-dev (2018-09-20-12:52)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 20000 kHz
esp32 interrupt mask on
Info : ftdi: if you experience problems at higher adapter clocks, try the command "ftdi_tdo_sample_edge falling"
Info : clock speed 20000 kHz
Info : esp32: Debug controller was reset (pwrstat=0xFF, after clear 0xFF).
Info : esp32: Core was reset (pwrstat=0xFF, after clear 0xFF).
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 225): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: esp32_fetch_all_regs (line 255): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Error: Exception reading pc!
Info : Target halted. PRO_CPU: PC=0x00000000 (active)    APP_CPU: PC=0x00000000
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_write_memory (line 759): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : esp32: Failed writing 4 bytes at address 0x3FF5F064, data - a1, 3a, d8, 50, a1, 3a, d8, 50
embedded:startup.tcl:21: Error:
in procedure 'program_esp32'
in procedure 'init' called at file "/home/ajay/esp/openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 119
in procedure 'ocd_bouncer'
in procedure 'esp_smp_break_config'
in procedure 'esp32' called at file "/home/ajay/esp/openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 54
in procedure 'esp_core_halt'
in procedure 'esp32' called at file "/home/ajay/esp/openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 44
at file "embedded:startup.tcl", line 21
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates target still busy!
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates DIR instruction generated an exception!
Error: cpu0: xtensa_read_memory (line 652): DSR (FFFFFFFF) indicates DIR instruction generated an overrun!
Warn : cpu0: Failed reading 4 bytes at address 0x3FF00030
Error: Failed to read target memory (-4)!
cpu0: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
cpu1: Current bits set: BreakIn BreakOut RunStallIn DebugModeOut
Warn : cpu0: Failed reading 76 bytes at address 0x50000000
Error: esp32_soc_reset 523 err=-4
in procedure 'reset' called at file "/home/ajay/esp/openocd-esp32/share/openocd/scripts/target/esp32.cfg", line 124
** Unable to reset target **
shutdown command invoked
BTW i am able to program the ESP32-DEVKIT-C-V4 using the same method without any problems. The issue is only with SOLO.
Re: Unable to program ESP32-SOLO-1
Postby Sprite » Sat Oct 06, 2018 4:53 am
Fwiw: 'Error: JTAG scan chain interrogation failed: all ones' usually means there's something wrong on a very low level: the JTAG adapter physically cannot talk to the JTAG hardware. Are you sure the SOLO-1 does not have a program in it that reconfigures the JTAG pins for something else?
ajaykk
Postby ajaykk » Sat Oct 06, 2018 5:51 am
This is a fresh module and first time programming it.
can you give us proper connection details and configurations for this module?
beegee1962
Contact:
Postby beegee1962 » Tue Oct 09, 2018 3:13 am
EDIT:
Below shown problem is solved by keeping the BOOT button pressed while the firmware is downloaded.
I read about similar problems with cheap Chinese dev boards, but this board is an original Espressif DevKitC-S1.
Was not expecting a bad HW design from Espressif.
-------------- SOLVED --------------
Similar problem here. ESP32-SOLO is showing on serial port, I can get debug output when starting the module.
Get as well the
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_REO_V2))
waiting for download
when pushing EN and BOOT.
But when I try to flash the module I get only
$ make flash
Toolchain path: /opt/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc
Toolchain version: crosstool-ng-1.22.0-80-g6c4433a5
Compiler version: 5.2.0
Python requirements from B:/msys32/home/BeeGee/esp/esp-idf/requirements.txt are satisfied.
Flashing binaries to serial port COM21 (app at offset 0x10000)...
esptool.py v2.5.1
Serial port COM21
Connecting........_____....._____....._____....._____....._____....._____....._____
make: *** [/home/BeeGee/esp/esp-idf/components/esptool_py/Makefile.projbuild:63: flash] Error 2
Where did you find single core mode in menuconfig? I cannot find this setting.
Do I need different toolchain or have to clone a different ESP-IDF version to flash the SOLO?
Or do I need extra settings in make?
ajaykk
Postby ajaykk » Tue Oct 09, 2018 12:08 pm
My esp-solo module was faulty. I tried with another solo module, was able to flash program using serial bootloader but when trying with JTAG, I am getting this message:-
$~/esp/openocd-esp32/bin/openocd -s ~/esp/openocd-esp32/share/openocd/scripts -f interface/ftdi/esp32_devkitj_v1.cfg -f board/esp-wroom-32.cfg -c "program_esp32 build/app-template.bin 0x10000 verify exit"
Open On-Chip Debugger 0.10.0-dev (2018-09-20-12:52)Licensed under GNU GPL v2
none separate
Info : JTAG tap: esp32.cpu1 tap/device found: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Warn : JTAG tap: esp32.cpu1       UNEXPECTED: 0xffffffff (mfg: 0x7ff (<invalid>), part: 0xffff, ver: 0xf)
Error: JTAG tap: esp32.cpu1  expected 1 of 1: 0x120034e5 (mfg: 0x272 (Tensilica), part: 0x2003, ver: 0x1)
Error: esp32.cpu1: IR capture error; saw 0x1f not 0x01
cpu0: Current bits set: none
Error: timed out while waiting for target halted / 1 - 2
You don't need anything extra, this setting is under > Component config > FreeRTOS
beegee1962
Contact:
Postby beegee1962 » Wed Oct 10, 2018 2:40 am
Thanks for your feedback.
I found the settings in menuconfig already.
But still have the problem that I need to push BOOT button while flashing over USB.
Don't have a JTAG adapter (yet), so I cannot test flashing over JTAG.
Users browsing this forum: Applebot, Bing [Bot], Bytespider, ChatGPT-User, Semrush [Bot] and 1 guest
