ESP32 Arduino WiFi + Eddystone beacon
ayandas4
Postby ayandas4 » Thu Mar 21, 2019 5:36 am
I'm designing a device with with Wi-Fi, EEPROM, GPIO functions, and also trying to make the device advertise an Eddystone URL. After I added BLEDevice, I faced Sketch too big issue. To solve that issue, I changed the default partition to increase the program memory area. I also tried selecting partition scheme "No Ota (Large APP)", the sketch size issue got solved. But the advertise data is not correct, the device advertises something else.
Attached the screenshot of the raw data captured using nRF Connect APP.
Here is the BLE (Eddystone) Initialization code:
BLEAdvertising *pAdvertising;
String product_url = "bit.ly/Brizo64a";
Initialize Bluetooth Low energy for Eddystone
void BLE_Init() {
  char beacon_data[36];
  uint16_t beaconUUID = 0xFFAA;   // UUID for Eddystone Service
  int url_length;
  int count;
  // Create BLE device
  BLEDevice::init("UniShelf");
  // Create BLE Server
  BLEServer *pServer = BLEDevice::createServer();
  pAdvertising = pServer->getAdvertising();
  //setBeacon();
  BLEAdvertisementData oAdvertisementData = BLEAdvertisementData();
  oAdvertisementData.setFlags(0x06);    // GENERAL_DISK_MODE 0x02 | BR_EDR_NOT_SUPPORTED 0x04
  oAdvertisementData.setCompleteServices(BLEUUID(beaconUUID));
  //beacon_data[0] = 0x20;    // Eddystone Frame Type (Unencrypted Eddystone - TLM)
  beacon_data[0] = 0x02;      // Length
  beacon_data[1] = 0x01;      //
  beacon_data[2] = 0x06;      //
  beacon_data[3] = 0x03;      // Length
  beacon_data[4] = 0x03;      // Flag - Complete list of 16-bit Service UUIDs data type value
  beacon_data[5] = 0xAA;      // 16bit Eddystone UUID
  beacon_data[6] = 0xFE;      // ...
  url_length = product_url.length();
  beacon_data[7] = url_length+6;      // Length
  beacon_data[8] = 0x16;      // Frame Type - Service Data
  beacon_data[9] = 0xAA;      // Eddystone
  beacon_data[10] = 0xFE;      //
  beacon_data[11] = 0x10;      // Frame Type - URL
  beacon_data[12] = 0x00;      // Tx power 4dBm?
  beacon_data[13] = 0x03;      // URL Scheme Prefix - https://
  for(count=0; count<url_length; count++) {
    beacon_data[14+count] = product_url.charAt(count);
  beacon_data[14+count] = 0xFF;
#ifdef DEBUG
  Serial.print("Beacon Data: ");
  for(count=0; count<url_length+15; count++) {
    if(beacon_data[count] < 16){
      Serial.print('0');
    Serial.print(beacon_data[count], HEX);
    Serial.print(' ');
  Serial.println();
#endif
  oAdvertisementData.setServiceData(BLEUUID(beaconUUID), std::string(beacon_data, url_length+15));
#ifdef DEBUG
  Serial.println("Service Data set!");
#endif
  pAdvertising->setScanResponseData(oAdvertisementData);
#ifdef DEBUG
  Serial.println("Scan response set!");
#endif
  // Start advertising
  pAdvertising->start();
#ifdef DEBUG
  Serial.println("Advertising started...");
#endif
  delay(5000);
The debug log seems to be saying that the advertisement data set is completed.
Debug log:
[D][BLEDevice.cpp:82] createServer(): >> createServer
[D][BLEServer.cpp:290] registerApp(): >> registerApp - 0
[D][FreeRTOS.cpp:165] take(): Semaphore taking: name: RegisterAppEvt (0x3ffe461c), owner: <N/A> for registerApp
[D][FreeRTOS.cpp:174] take(): Semaphore taken:  name: RegisterAppEvt (0x3ffe461c), owner: registerApp
[V][FreeRTOS.cpp:70] wait(): >> wait: Semaphore waiting: name: RegisterAppEvt (0x3ffe461c), owner: registerApp for registerApp
[D][BLEDevice.cpp:108] gattServerEventHandler(): gattServerEventHandler [esp_gatt_if: 4] ... ESP_GATTS_REG_EVT
[V][BLEUtils.cpp:1519] dumpGattServerEvent(): GATT ServerEvent: ESP_GATTS_REG_EVT
[V][BLEUtils.cpp:1709] dumpGattServerEvent(): dumpGattServerEvent: *** NOT CODED ***
[D][BLEServer.cpp:153] handleGATTServerEvent(): >> handleGATTServerEvent: ESP_GATTS_REG_EVT
[V][FreeRTOS.cpp:120] give(): Semaphore giving: name: RegisterAppEvt (0x3ffe461c), owner: registerApp
[D][BLEServer.cpp:280] handleGATTServerEvent(): << handleGATTServerEvent
[V][FreeRTOS.cpp:86] wait(): << wait: Semaphore released: name: RegisterAppEvt (0x3ffe461c), owner: registerApp
[D][BLEServer.cpp:294] registerApp(): << registerApp
[D][BLEDevice.cpp:89] createServer(): << createServer
[I][BLEDevice.cpp:561] getAdvertising(): create advertising
[D][BLEDevice.cpp:563] getAdvertising(): get advertising
02 01 06 03 03 AA FE 15 16 AA FE 10 00 03 62 69 74 2E 6C 79 2F 42 72 69 7A 6F 36 34 61 FF
Service Data set!
[D][BLEAdvertising.cpp:169] setScanResponseData(): >> setScanResponseData
[D][BLEAdvertising.cpp:177] setScanResponseData(): << setScanResponseData
[V][BLEUtils.cpp:1038] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_SCAN_RSP_DATA_RAW_SET_COMPLETE_EVT
[V][BLEUtils.cpp:1253] dumpGapEvent(): *** dumpGapEvent: Logger not coded ***
[D][BLEAdvertising.cpp:186] start(): >> start: customAdvData: 0, customScanResponseData: 1
[D][BLEAdvertising.cpp:205] start(): - no services adverti[D][BLEAdvertising.cpp:205] start(): - no services advertised
[D][BLEAdvertising.cpp:479] handleGAPEvent(): handleGAPEvent [event no: 5]
[D][BLEAdvertising.cpp:246] start(): << start
[V][BLEUtils.cpp:1038] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_ADV_DATA_SET_COMPLETE_EVT
[D][BLEAdvertising.cpp:479] handleGAPEvent(): handleGAPEvent [event no: 0]
[V][BLEUtils.cpp:1038] dumpGapEvent(): Received a GAP event: ESP_GAP_BLE_ADV_START_COMPLETE_EVT
[D][BLEAdvertising.cpp:479] handleGAPEvent(): handleGAPEvent [event no: 6]
ayandas4
Re: ESP32 Arduino WiFi + Eddystone beacon
Postby ayandas4 » Fri Mar 22, 2019 5:41 am
Now I wrote a code with only BLE, in default partition.. and nothing else. It still doesn't advertise the parameters I'm giving.
#include "BLEDevice.h"
#include "BLEUtils.h"
#include "BLEServer.h"
//#include "esp_sleep.h"
/******************** BLE ************************************/
  int url_length;
  int count;
  //setBeacon();
  //beacon_data[14+count] = 0xFF;
#ifdef DEBUG
      Serial.print('0');
    Serial.print(' ');
  Serial.println();
#endif
  oAdvertisementData.setServiceData(BLEUUID(beaconUUID), std::string(beacon_data, url_length+14));
#ifdef DEBUG
#endif
#ifdef DEBUG
#endif
#ifdef DEBUG
#endif
  delay(5000);
the loop function runs over and over again forever
chegewara
Postby chegewara » Fri Mar 22, 2019 1:45 pm
i checked your code and its data length exceeds advertising data length (31 bytes). Your advertising data length is 40 bytes.
ayandas4
Postby ayandas4 » Sun Mar 24, 2019 1:12 pm
Thanks for your response.
My understanding may be wrong... but "bit.ly/Brizo64a" is 15 bytes, and beacon_data[] is loaded with 15 bytes prior to it, that comes to total 30 bytes. Am I missing something?
Regards
Ayan
ayandas4
Postby ayandas4 » Mon Mar 25, 2019 5:59 am
The problem is solved. It was mostly misunderstanding of the beacon advertisement data setting. I was doing repeated settings through the API as well as the raw data. here is the working code:
#define DEBUG
void setBeacon() {
  uint16_t beaconUUID = 0xFEAA;   // UUID for Eddystone Service
  int url_length;
  int count;
  beacon_data[0] = 0x10;      // Frame Type - URL
  beacon_data[1] = 0x00;      // Tx power 4dBm?
  beacon_data[2] = 0x03;      // URL Scheme Prefix - https://
    beacon_data[3+count] = product_url.charAt(count);
#ifdef DEBUG
  for(count=0; count<url_length+3; count++) {
      Serial.print('0');
    Serial.print(' ');
  Serial.println();
#endif
  oAdvertisementData.setServiceData(BLEUUID(beaconUUID), std::string(beacon_data, url_length+3));
#ifdef DEBUG
#endif
#ifdef DEBUG
#endif
  setBeacon();
#ifdef DEBUG
#endif
  delay(5000);
