the documentation says that this pin is pulled up to 3v3 via 10K resistor, if I want to use this DAC output does that mean I have to remove the shield and remove R11 first?
https://www.espressif.com/sites/default ... eet_en.pdf
The problem I see is that DAC 2 is stuck at 2.68V while DAC 1 just works fine.
Using DAC2 on ESP32-S2-Mini-1U
PepeTheGreat
Re: Using DAC2 on ESP32-S2-Mini-1U
Same issue. Why is there a 10k to vcc? To keep rx1 up?
Removing this should help: https://imgur.com/a/4MqclGo
- s2_mini_v1.0.png (745.29 KiB) Viewed 1379 times
Users browsing this forum: Bing [Bot], Google [Bot], PerplexityBot and 5 guests
