Using DAC2 on ESP32-S2-Mini-1U
MarkusR
Postby MarkusR » Tue May 17, 2022 6:32 am
the documentation says that this pin is pulled up to 3v3 via 10K resistor, if I want to use this DAC output does that mean I have to remove the shield and remove R11 first?
https://www.espressif.com/sites/default ... eet_en.pdf
The problem I see is that DAC 2 is stuck at 2.68V while DAC 1 just works fine.
yuliksan
Re: Using DAC2 on ESP32-S2-Mini-1U
Postby yuliksan » Tue Jul 26, 2022 7:54 am
Hi, MarcusR
Did you solve the problem?
PepeTheGreat
Postby PepeTheGreat » Wed Feb 07, 2024 3:58 pm
Same issue. Why is there a 10k to vcc? To keep rx1 up?
Removing this should help: https://imgur.com/a/4MqclGo
Users browsing this forum: Google [Bot], Semrush [Bot], YisouSpider and 4 guests
