I have a question about the GPIO wake up in the ESP32-C6 chip.
I used to have a ESP32-C3, which uses esp_deep_sleep_enable_gpio_wakeup() to enable certain GPIOs to wake up deep sleep.
But after checking the ESP32-C6 manual, I found that GPIOs can only wake up light sleep. Is esp_deep_sleep_enable_gpio_wakeup() removed in C6?
ESP32-C6 sleep manual:
https://docs.espressif.com/projects/esp ... modes.html
ESP32-C3 sleep manual:
Could anyone confirm this? Any suggestion would be greatly appreciated.
Can ESP32-C6 use GPIO to wake up Deep Sleep?
- C6 manual.png (72.91 KiB) Viewed 15209 times
- C3 manual.png (39.45 KiB) Viewed 15209 times
Re: Can ESP32-C6 use GPIO to wake up Deep Sleep?
Not the answer you might be looking for, but I'm using esp_sleep_enable_ext1_wakeup() and that works fine on the C6.
Thanks but I still want to use GPIO to wake up DeepSleep.Not the answer you might be looking for, but I'm using esp_sleep_enable_ext1_wakeup() and that works fine on the C6.
I noticed that External Wakeup can be used to wake DeepSleep with RTC GPIO, but I didn't find any description on the web about which pin of the ESP32 C6 can be multiplexed as RTC GPIO.
Can you make a suggestion?
The code reference only describe the API, but not mentioned about physical pins:
https://docs.espressif.com/projects/esp ... /gpio.html
See the datasheet, section 2.3.2. Long story short: GPIO0 to GPIO7 are RTC (LP) GPIOs.I noticed that External Wakeup can be used to wake DeepSleep with RTC GPIO, but I didn't find any description on the web about which pin of the ESP32 C6 can be multiplexed as RTC GPIO.
lbernstone
Just an fyi here that maybe will keep someone else from wasting their time- the esp32-c6 ulp does not have access to the ADC peripheral.
Does anybody know what the LP Analog Peripheral is?
In the TRM there is the LP_ANA_PERI from Table 5-2, but that is not referenced anywhere else in the TRM.
also below that same table there is the note:
Though presumably it is conditioned on the active power domains?• LP CPU can access all peripherals listed in the table 5-2 except RISC-V Trace Encoder (TRACE), DEBUG ASSIST
(ASSIST_DEBUG) and Interrupt Priority Register (INTPRI).
lbernstone
There is no ADC (analog) peripheral accessible by the LP-core on a ESP32-C6.
That is technically incorrect: the ESP32-C6 can access all peripherals except the ones quoted because it has full access to the same bus as the main processor. I'll ask if there is a more 'native' way that also works in deep sleep; I agree that esp-idf and the documentation don't seem to mention one.There is no ADC (analog) peripheral accessible by the LP-core on a ESP32-C6.
lbernstone
It would make me very happy if you are correct, but https://github.com/espressif/esp-idf/issues/13422That is technically incorrect: the ESP32-C6 can access all peripherals except the ones quoted because it has full access to the same bus as the main processor. I'll ask if there is a more 'native' way that also works in deep sleep; I agree that esp-idf and the documentation don't seem to mention one.
