How to fix "include path " problems in VS code IDE?
Pony Ma
Postby Pony Ma » Mon Jan 11, 2021 8:57 am
When started up with Visual Studio Code , This problem happened.
Thanks for help...
include path.png (99.73 KiB) Viewed 39289 times
TinkerBearNZ
Re: How to fix "include path " problems in VS code IDE?
Postby TinkerBearNZ » Tue Jan 12, 2021 1:34 am
Do you have the C/C++ Extension installed?
I'm struggling to remember what I did to fix this, but I believe it's a matter of letting or making the C/C++ extension use build/compile_commands.json to find the proper include path.
compile_commands.json is available after you've done your first build.
abansal22
Postby abansal22 » Tue Jan 12, 2021 7:41 am
These combination of the extension version works for me.
c/c++ ver 1.1.3
Espressif idf 0.5.1
Also to get rid of the error lines, you need to build the project first. Only after that vscode will be able to find the headers. Thanks!
Haidar
Postby Haidar » Thu Nov 18, 2021 1:20 pm
I had he same problem, I downloaded MinGW compiler then I added his directory to the "environment variable" -or something like that- then it was solved, but the build failes, and there is an error in he C/C++ cofiguration (UI) displaying:
Cannot find: ${env:IDF_PATH}/components/
Cannot find: ${env:ADF_PATH}/components/
and I'm searching for a solution right now.
atemiz
Postby atemiz » Sun Apr 03, 2022 12:23 pm
Add compile_commands.json to your c_cpp_properties.json
"compileCommands": "${workspaceFolder}/build/compile_commands.json"
ohsnapfit
Postby ohsnapfit » Wed May 04, 2022 11:37 pm
I have the same issue and am following along. How do I " Add compile_commands.json to your c_cpp_properties.json"
Currently my c_cpp_properties.json file is
"configurations": [
"name": "Win32",
"includePath": [
"${workspaceFolder}/**",
"${config:idf.espIdfPath}/components/**"
"browse": {
"path": [
"${config:idf.espIdfPath}/components"
"limitSymbolsToIncludedHeaders": false
"defines": [
"_DEBUG",
"UNICODE",
"_UNICODE"
"cStandard": "c17",
"cppStandard": "c++17",
"intelliSenseMode": "windows-gcc-x64",
"configurationProvider": "ms-vscode.cpptools",
"compilerPath": "C:\\.espressif\\tools\\xtensa-esp32-elf\\esp-2021r2-patch3-8.4.0\\xtensa-esp32-elf\\bin\\xtensa-esp32-elf-gcc.exe"
"version": 4
atemiz
Postby atemiz » Thu May 05, 2022 9:17 pm
As an example, the configuration file content that I am currently using is as follows;
    "configurations": [
            "name": "ESP32-C3",
            "includePath": [
                "${default}"
            "defines": [
                "_DEBUG",
                "UNICODE",
                "_UNICODE"
            "cStandard": "c17",
    "version": 4
medley56
Postby medley56 » Mon May 05, 2025 5:09 pm
I think since v5.0 when they moved to CMake, these instructions need updating. Or possibly the C/C++ VSCode extension changed its configuration. Regardless, this worked for me:
In the C/C++ extension settings in the section for Intellisense, update the value for
"C_Cpp.default.compileCommands": [
As mentioned elsewhere, this won't work until you've successfully compiled the project and the json file is in the build directory.
Users browsing this forum: Baidu [Spider], Bing [Bot], Bytespider, ChatGPT-User, DuckDuckGo [Bot], PerplexityBot, Qwantbot and 2 guests
