How to fix "include path " problems in VS code IDE?
When started up with Visual Studio Code , This problem happened.
Thanks for help...
Thanks for help...
- include path.png (99.73 KiB) Viewed 39283 times
- TinkerBearNZ
Re: How to fix "include path " problems in VS code IDE?
Do you have the C/C++ Extension installed?
I'm struggling to remember what I did to fix this, but I believe it's a matter of letting or making the C/C++ extension use build/compile_commands.json to find the proper include path.
compile_commands.json is available after you've done your first build.
These combination of the extension version works for me.
c/c++ ver 1.1.3
Espressif idf 0.5.1
Also to get rid of the error lines, you need to build the project first. Only after that vscode will be able to find the headers. Thanks!
c/c++ ver 1.1.3
Espressif idf 0.5.1
I had he same problem, I downloaded MinGW compiler then I added his directory to the "environment variable" -or something like that- then it was solved, but the build failes, and there is an error in he C/C++ cofiguration (UI) displaying:
Cannot find: ${env:IDF_PATH}/components/
Cannot find: ${env:ADF_PATH}/components/
and I'm searching for a solution right now.
Add compile_commands.json to your c_cpp_properties.json
"compileCommands": "${workspaceFolder}/build/compile_commands.json"Re: How to fix "include path " problems in VS code IDE?
I have the same issue and am following along. How do I " Add compile_commands.json to your c_cpp_properties.json"Add compile_commands.json to your c_cpp_properties.json
Currently my c_cpp_properties.json file is
"configurations": [
"name": "Win32",
"includePath": [
"${workspaceFolder}/**",
"${config:idf.espIdfPath}/components/**"
"browse": {
"path": [
"${config:idf.espIdfPath}/components"
"limitSymbolsToIncludedHeaders": false
"defines": [
"_DEBUG",
"UNICODE",
"_UNICODE"
"cStandard": "c17",
"cppStandard": "c++17",
"intelliSenseMode": "windows-gcc-x64",
"configurationProvider": "ms-vscode.cpptools",
"compilerPath": "C:\\.espressif\\tools\\xtensa-esp32-elf\\esp-2021r2-patch3-8.4.0\\xtensa-esp32-elf\\bin\\xtensa-esp32-elf-gcc.exe"
"version": 4
As an example, the configuration file content that I am currently using is as follows;I have the same issue and am following along. How do I " Add compile_commands.json to your c_cpp_properties.json"Add compile_commands.json to your c_cpp_properties.json
"configurations": [
"name": "ESP32-C3",
"includePath": [
"${default}"
"defines": [
"_DEBUG",
"UNICODE",
"_UNICODE"
"cStandard": "c17",
"version": 4
I think since v5.0 when they moved to CMake, these instructions need updating. Or possibly the C/C++ VSCode extension changed its configuration. Regardless, this worked for me:
In the C/C++ extension settings in the section for Intellisense, update the value for
As mentioned elsewhere, this won't work until you've successfully compiled the project and the json file is in the build directory.
"C_Cpp.default.compileCommands": [
Users browsing this forum: ChatGPT-User, Semrush [Bot] and 2 guests
