MCPWM
morris
Re: MCPWM
Postby morris » Mon Jun 20, 2022 4:34 am
i have saw that the mcpwm module can't perceive the DFS.
i need to call the function of esp_pm_lock_acquire(ESP_PM_APB_FREQ_MAX) when i use the mcpwm module, and need to call the function of esp_pm_lock_release(ESP_PM_APB_FREQ_MAX) when i stop the pwm.
is it right?
yes, the application can create a pm lock, and acquire/release the lock when we start/stop the mcpwm timer.
chenyananee
Re: MCPWM
Postby chenyananee » Mon Jun 20, 2022 5:45 am
another question about the capture, see the picture for more details.
1.
how can i fix this issue with picture 1
2.
and i don't know the means about the value 10000,10000000000, this is from the example code.
i want to calculate the frequence about the input signal. i need the max value of the timer count and the clock frequence.
chenyananee
Re: MCPWM
Postby chenyananee » Mon Jun 20, 2022 7:44 am
when i call the api(current_cap_val = mcpwm_capture_signal_get_value(MCPWM_UNIT_0, MCPWM_SELECT_CAP0);) from the capture interrupt function, thie issue will appear by high frequence.
chenyananee
Re: MCPWM
Postby chenyananee » Tue Jun 21, 2022 7:26 am
i have find the reason of the interrupt error.
and i don't call the api from the flash this issue can be fixed.such like this picture ...
just for the calculation of the frequency, the input signal is 1kHz but we can see the result is 875 form the terminal log. so there is something wrong with this formula.
cap fix.png (38.89 KiB) Viewed 3751 times
chenyananee
Re: MCPWM
Postby chenyananee » Tue Jun 21, 2022 7:47 am
maybe we can close this issue.
cap ok.png (33.28 KiB) Viewed 3742 times
chenyananee
Re: MCPWM
Postby chenyananee » Tue Jun 21, 2022 9:45 am
clock is the apb clock,and there is no prescale.
so the input frequency is apb_clk/Δ.
test is ok for 1k,500Hz and so on.
